Check Engine light
JDC2TypeR
Check Engine light
Post by JDC2TypeR »
After i got the P28 ECU chip with S300, i follow all the installation instruction and i plug it onto my 98 gsr with a 98 spec jdm itr engine swap, and turn ignition on and the check engine light comes. i data log and it says knock sensor, how do i fix that? i already try to delete dts but it comes back and i already try to disable knock sensor but my car wouldnt start. help???
To read error codes you must datalog.
boricua
Re: Check Engine light
Post by boricua »
JDC2TypeR wrote:After i got the P28 ECU chip with S300, i follow all the installation instruction and i plug it onto my 98 gsr with a 98 spec jdm itr engine swap, and turn ignition on and the check engine light comes. i data log and it says knock sensor, how do i fix that? i already try to delete dts but it comes back and i already try to disable knock sensor but my car wouldnt start. help???
Mine is the driving me crazy, i jump for codes and the check engine light goes off and the srs light starts blinking constantly and never stops.
94 vx with n/a type r, how can i read the code if it goes out?
Sorry don't mean to jack your thread
Spunkster wrote:To read error codes you must datalog.
