K-pro and stock fuel maps
jsonxyz
Post by jsonxyz »
I have 2005 civic si ,jrsc,440 injectors,exhaust,header,intake,10lb pulley,cluth,lightweight,flywheel.When i datalog its reading 21psi at around 6300 rpm.I know this is impossable.Is somthing wrong with K-pro or stock map sensor.
Go to Options, Settings, and in the Units Tab select the correct Units and base units.
jsonxyz
Post by jsonxyz »
It still reads the same .I put it on kpa and it read 147.8 that break s down to the same on 21psi
Change the base units also
