Hondata Prepared chipped P28 ECU
aznrukus
Post by aznrukus »
Hey i just recently recieved your Hondata Prepared chipped P28 ECU.
I ordered from you guys last week and i just recieved it yesterday. When i went check the ECU when i got home i noticed a couple of things. First the sticker on the side said P06 which i know comes from USDM Non-vtec. Secondly on the top of the ECU i was marked 92-05 civic DX 5spd. When i ordered a Hondata chipped OBD1 92-95 CIVIC SI/EX P28. When i researched online i went to compare ECU's, i ran into couple places that said that there has been some ECU converted from P06 to P28. Hopefully i didn't get that because specifcally ordered the P28. I'm not really choked cause it could be a mistake or what not i just clarifactions on what happened. I order from you guys alot and this is only mishappen. Underneath i enclosed photos of the ECU. I just want to get what i payed for what i ordered.
Thanks in advance,
Aznrukus
Who did you order this from....what dealer?
This is not a Hondata prepared ecu.
aznrukus
Post by aznrukus »
Spunkster wrote:Who did you order this from....what dealer?
I got it from a local Canadian Dealer. I showed them the ECU and it was a mix up so they are replacing it and i'm finally going to get me Hondata prepare ecu. Thanks for the help.
What canadian dealer was it?
Garrett_si
Post by Garrett_si »
This ECU is a p06 converted to P28 spec, with vtec
but this is not Hondata at all...
