06 rsx type-s question.......
Gizmo Dc5
Post by Gizmo Dc5 »
ok so if with my current setup(injenCAI,DCRH, Fujitsubo Rm01a exhaust) it runs so rich at high rpm that when i shift sometimes fire shoots out. so i wanna know if u all think it would be ok to get the 05-06 reflash since that leans out a bit up top?
What is not recommended:
Stock Airbox
Race header
Race camshafts
Forced induction
Check your catback exhaust carefully. The internal diameter of the rear muffler is often smaller than stock. If this is the case you will probably make less power than stock with more noise. It will work OK with a stock airbox but you will not see these advertised power gains, and you may feel a dip after VTEC.
If you have a race header you will run lean. This is not a result of the Hondata reflash. Even the stock ECU will run lean with a race header. If you intend to run race headers we recommend you upgrade to a Hondata K-Pro for the 05 RSX.
