S200 blue box question and check engine light
turbocivic
Post by turbocivic »
real simple question here. With a correctly working S200 system, can you still pull the check engine codes via the 2 wire jumper? (laptop not available!))
Once a S200 system has been set up and tuned, is any important info store within the blue box? Could you swap in a friends blue box to test if you thought you had a bad blue box? Both cars are N/A, but one is tuned with E85.
yes and yes
