S300 cel light, error code
srcracing
Post by srcracing »
98 Prelude H22 supercharged, Hondata OBDII computer with internal OBD I to II plug, S300, socketed by Hondata. DTC error #9. I've checked triggers and wiring at ECU connecter with osciliscope and have a good wave forum. Any ideas why I still have CEL and error code?
George Landis
srcracing@aol.com
srcracing.com
561-394-4359
Some Preludes have a wiring change that is not documented anywhere. You will have to check the distributor wiring using a multimeter to make sure they are going to the right places on the ecu. No one has ever let us know what the exact resolution to the problem was.
srcracing
wave forms
Post by srcracing »
What wave forms should I see, for these triggers? TDC, (I would think 1 ref per tdc event) CKP (24 evemts per 720 degrees), CYP (1 event just before #1 TDC) Is this correct?
George Landis
srcracing@aol.com
srcracing.com
561-394-4359
