GM Air Temp Sensor
secretpickle
GM Air Temp Sensor
Post by secretpickle »
Anyone know if this will work with kpro? Does it utilize the correct range and such:
http://www.rs-autosport.net/catalog/pro ... cts_id=216
GM Air Temp Sensor
Currently my air temp sensor is before the turbo which is OK but not the best location for it. I wanna use this temp sensor so I don't have to make threads on my current plastic IAT sensor. This looks a lot better and it's only $20... Maybe I'll just order it and see how it goes lol... I wanna tap it into my intake manifold right before my methanol injection nozzle.
Matt
You will be much better off just getting the IAT sensor from an Integra. It has 2 holes to secure it with screws and seals with an o-ring.
secretpickle
ic and this will work with kpro eh?
yes, the plugs may be different so you may need that from a junk yard as well.
locash
Post by locash »
Just so you know, I made an aluminum adapter that you can weld to aluminum charge piping, and it allows you to use the stock K-Series IAT sensor.. Full-Race uses these on all of their K-series kits now.. If you need one, drop me a line..
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
secretpickle
locash wrote:Just so you know, I made an aluminum adapter that you can weld to aluminum charge piping, and it allows you to use the stock K-Series IAT sensor.. Full-Race uses these on all of their K-series kits now.. If you need one, drop me a line..
mk how much? PM me all up on crsx: secretpickle
locash
Post by locash »
I don't visit crsx, drop me a line at joe@locashracing.com
Locash Racing, LLC
