Error Code: P1298-high voltage ELD
SiR R8TD
Post by SiR R8TD »
I have an 03' EP3 w/ a full K20Z1 swap along w/ trans. Everything works fine, but when I enabled OBDII, I got the P1298 error when I was datalogging. The check engine light has not come on yet. Does anyone know what going on? The ELD sensor reads -12.80 when it's running.
EP3 K20Z1
I would suggest following the helms manual for this error code. You will have problems with the speed signal and an 05-06 transmission which will also cause problems with vtec activation.
SiR R8TD
Post by SiR R8TD »
every thing has been converted & is fully functional! I just keep getting the ELD error.
EP3 K20Z1
There is nothing to convert for this when it comes to the ELD, which is why you need to follow the Helms to troubleshoot it.
