Question about using a wideband with s300
larby
Post by larby »
hi, this may be a stupid question... I'm installing a s300 in my EG civic, and i will be using an AEM wideband to tune. I'm aware i can link this to the s300 for datalogging, and autotune on the fuel tables, which i intend to do, but what happens about the stock o2 signal?
i can select either 0-5v output or 0-1v output from my wideband, not both at one time. i'll obviously have it set to 0-5v for tuning purposes, and as i'm not running the stock sensor anymore, does it matter that i will no longer have a 0-1v signal? is there some setting in smanager i havent seen to allow for this?
sorry to sound so vague, i've confused myself here i think!
thanks in advance,
James
You'll have to switch between open loop with wideband output and closed loop using the narrrow band output.
PLX has both wide and narrow band outputs.
larby
Post by larby »
balls. in a word! i got the AEM on the advice of your dealer in the uk, wish i'd gone with my choice of the PLX now! doh! :roll:
