Onboard Datalog playback
SPOOLIN
Post by SPOOLIN »
when i playback or scroll accross the datalogs from the on board logs, how can i make it read the map sensor readings in PSi after it passes from vacuum to boost?
www.MSSRACING.com
9.29 | 6.20 | 167
make sure you go to Options, settings and set the Units you want, and double click the MAP in the sensor window and make sure you also set the units you want there.
