S300 with D16A9 (OBD0)
Will_sg
Post by Will_sg »
Can the S300 be used with the above engine? I will be turbo-charging the engine.
My intention is to get the OBD0 to OBD1 Adapter Harness and S300 chipped ECU. Check if there is anything else I will need? e.g. can I still use the OBD0 dizzy?
If in the future, I wish to swap in a B16A, can I reuse the ECU? (VTEC?)
thanx
http://www.hondata.com/techobd0conversion.html
I do not know if there is a bolt on OBD1 distributor you will be able to use.
Will_sg
Post by Will_sg »
Spunkster wrote:http://www.hondata.com/techobd0conversion.html
Just found out the TD-43U distributor for 2nd Gen OBD1 DOHC ZC engine will fit nicely.
My next question will be, since I am using it on a OBD0 engine, would it mean I will not need the harness with additional for vtec, oxygen senor and other sensor?
There is only one OBD0-OBD1 adapter.
