Limiter
brooklyngenius
Limiter
Post by brooklyngenius »
Ok I just recently got the reflash on my 07 SI. I was told that the reflash removes the speed governor but now its limiting me to 130mph were as stock i was at 140. why??
There is no speed limiter on the US ECUs, either stock or with the reflash.
brooklyngenius
ohhh yes there is on the 06-08 Si! the stock one limited you to 140mph and then cut fuel. everybody knows this to be true.
We've run the ECU on the dyno up to 168 mph, both in stock and reflashed form.
brooklyngenius
could something be wrong with my reflash then?
hawjdude
Post by hawjdude »
the si has been shown to limit around 130-140. i forget which it is. searching on youtube for si videos, u can find a video showing and testing the limiter.
Hondata wrote:We've run the ECU on the dyno up to 168 mph, both in stock and reflashed form.
Ok, with further testing the 2006 models do not have a speed limiter and the 2007 models have a 135 mph speed limiter.
brooklyngenius
yes thats the limiter thats pissing me off. I thought the reflash was supposed to remove that?
We'll look at removing it for future reflashes.
brooklyngenius
thats great but how will that help me? will I get a updated reflash later or something?
If we remove the speed limiter in the future then we'll offer an upgrade.
arlo03
Post by arlo03 »
when should that upgraded reflash happen? or has it already?
It is available now
