D10 ELD
RickyLee53
D10 ELD
Post by RickyLee53 »
When hooking up a wideband to D10 ELD, do i cut the wire on the ECU and solder my wideband to it.
Or do i splice into it leaving it connected to whatever its connected to as well?
hiperformance
Post by hiperformance »
White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU)
In other words, cut it.
RickyLee53
hiperformance wrote:White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU)
Right i did this, but now my problem is i don't know how to get the Hondata software to read it.
I've gone into close loop mode and told it the calibrations.
But i want to also monitor it as a sensor to make sure it is reading right.
The only "display" i can get is the "lambda" 1, but this isn't as an AFR (which i prefer) and it doesn't seem to correspond to the D10 pin.
Would it be easier just to choose a new pin? As i want to autotune and display wideband as an AFR on the screen.
Also the ECT (engine coolant temp) sensor isn't calibrated correctly it seems, as the engine was just started and was showing 100 degrees (celcuis) 170 ish F. How do i calibrate this sensor?
Many thanks.
What wideband are you using?
RickyLee53
Spunkster wrote:What wideband are you using?
Innovate LC1.
RickyLee53
analogue input 2 looks like the easiest input to use. But You can't watch this in the Display for some reason, whereas you can with AN1.
But AN1 needs a cap soldering in whereas AN2 just needs a couple of Resistor chops.
The instructions for this are pretty much the same for the LC1: http://www.hondata.com/techplxwiring.html
RickyLee53
Spunkster wrote:The instructions for this are pretty much the same for the LC1: http://www.hondata.com/techplxwiring.html
I've read those and installed it.
What i want to know is how i get to see what the wideband is doing on my laptop.
If i click the lamda button it displays the lambda figure but it doesn't tell me as an AFR to compare it to my gauge, even when i worked it out the figure wasn't the same as displayed on my XD16.
I guess it must be the voltage offset i need to change.
When i've got this working, how do i enable auto tune?
Double click on the AF item in the sensor list and change it to read AF instead of Lamba.
RickyLee53
Spunkster wrote:Double click on the AF item in the sensor list and change it to read AF instead of Lamba.
Thanks, thats what i needed :)
RickyLee53
I still can't get them to read the same.
How do i turn autotune on and off?
RickyLee53
Even playing with the voltage offset i can't get them to read the same all the time, i can get them to read the same for a certain AFR, say 15, then when it gets to 11, its way out.
Note that if the ELD input (D10) is used then R136 and R138 (US ECUs) may need to be removed.
DOHCAccord
Post by DOHCAccord »
when you say might, how can we tell besides having erratic wideband readings.
mike93hatch
Post by mike93hatch »
Spunkster wrote:Note that if the ELD input (D10) is used then R136 and R138 (US ECUs) may need to be removed.
cutting them fixed my wideband problems. yay, no more voltage offset and it can read lower than 11.8:1 now
