suggestions for injector size for type-r turbo
boosted crx-r
Post by boosted crx-r »
i got hondata s300 on a P72, jdm b18c type-r, 81 mm bore, 9:1 je pistons, eagle rods, Edelbrock intake manifold, venom fuel rail, plx wideband, Msd external blaster coil and cap, T3/T4 turbo with ramhom manifold, tial evolution 35mm wastegate, and 3" exhaust. Im gonna tune for 12 psi. and would like to know what injector size would be best.
shut up and boost it!
Injector size depends on the power output you plan to make. Discuss this with your tuner.
hondatechpr
Post by hondatechpr »
I suggest you to buy a 850cc because you will have enough fo the 12 psi and for much more, close to 650PH if you want, and have to buy injectors just once. And the best of all is that the Hondata will handle them pretty well
Integra 96 B20 Vtec nitrous 115hp 260hp total 12.00ET 115MPH Stock internals hondata S300
thething96
Post by thething96 »
You should get a minimum of 550's. I maxed out some 550's on a similar setup at 18 psi........
