Any way to run a B-Series IAC with kpro??
eggyoak
Post by eggyoak »
i am running a b-series throttle body with out a IAC... i have horrible part throttle right around injector cut off... i want to run a b-series IAC also but i was wondering on how to wire the 2 wire IAC with kpro... do i wire it like you would a OBD2 civic with a b-series swap???
The K-Series uses a rotary idle valve; the B-Series uses a linear solenoid. Number of pins are different too.
