SManager Beta V1.3.2
This is a beta release of SManager. The major change is to the Display window, which now has sensor displays similar to HondaLogger. More information can be found in the Help file, under 'Display Window'.
SManagerV1-3-2.exe
With the Beta it is possible that future updates will not be able to load the saved display settings, so don't put too much effort into your screens at this point.
Here are some diplay templates you can begin with:
turbotypeR
Post by turbotypeR »
what do i do to make this work. i downloaded the itr like display, but it loos the same
92 civic Si
best et:9.43best mph:164
deafy
Post by deafy »
save the display file to the smanager directory. With SManager open, click "display" at the top, then select "Load", then select the display file of your preference.
1997 Prelude - under the knife.
2000 Insight - k20z3 swap, pt6262, e85. 508whp@19psi.
mike93hatch
Post by mike93hatch »
BADASS!! hondata rocks!
keep coming out with some good updates :)
turbotypeR
got it! thanks!
92 civic Si
2 0 3
Re: SManager Beta
Post by 2 0 3 »
Hondata wrote: Here are some diplay templates you can begin with:
I dont see any links to download templates??
Something wrong with me/my computer or is someone else having this issue ???
Tchleung
Post by Tchleung »
Wow once again Hondata amazes me. :D:D
mike93hatch
Re: SManager Beta
you have to log in
turbotypeR
here's mine. i can't figure out how to change the colors to match on the injector duty cycle i added on the right. anybody know how? anyway, here ya go!:
92 civic Si
Tchleung
Post by Tchleung »
Here is mines:
turbotypeR: Double click on the button you want to adjust, then go to font value colour or somethin along the lines of that. There will be one that is default blakc, change that to white so you can see it say DUTY %, then find the one that changes the actual value, default is green, change that to white as well, or wvateher colours you want. you can see mines on my picture.
mike93hatch
turbotypeR wrote:here's mine. i can't figure out how to change the colors to match on the injector duty cycle i added on the right. anybody know how? anyway, here ya go!:
right click on it, goto properties click on font and it will open a window where you can change the font, size, and also the color, etc..
88ED8
Post by 88ED8 »
since were all posting pics heres mine :) (I like simple)
Check out my Turbo H2B CRX http://honda-tech.com/zerothread/2086488
marklamond
Post by marklamond »
Very nice, thanks for the update!
GTMcoupe
Post by GTMcoupe »
Been playing with this today, looking good
i have one problem which i cannot get around as of yet, i have set up a bar graph for AFR whilst finding out what can be done, i set up diferent colour bands for differing AFRs, however i can only select whole numbers for each colour band, eg blue 12 to 13 green 13 to 15, red 15 to 17, i cannot get it to do for example 12 to 12.5 everytime i put in a any.5 value i get an "this is not a valid integer value error
Any idea?
WEST
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
turbotypeR
GTMcoupe wrote:Been playing with this today, looking good
Any idea?
WEST
I had the same problem.never figured it out though
92 civic Si
