ELD voltage
Mr Aryan
ELD voltage
Post by Mr Aryan »
Just trying to connect the AEM gauge with the ELD...
i've put the volt vs AFR in the table..
from 14-15afr the gauge and the log show the same... less than 14 it starts to go off like .2...
anyway... my qustion is does the ELD reads less than 1 volt? cause when the gauge reads somewhere in 11s afr, the log stops at 12afr which equels to almost 1 volt.
as per the AEM gauge manual:
1.09 volt = 12.18afr
thanks
Yes, the ELD can read below 1V
hardcorersxs
Post by hardcorersxs »
for some reason, the datalog doesn't read below 12:1 af. Is it possible for the ELD on the Civic Type-R's to have different ELD voltage?
Mr Aryan
Post by Mr Aryan »
hardcorersxs wrote:for some reason, the datalog doesn't read below 12:1 af. Is it possible for the ELD on the Civic Type-R's to have different ELD voltage?
the ELD option was made for the euro civic type R only, because they don't run factory wideband o2
