please help high AFR?
bau98
Post by bau98 »
i got a vtec turbo,and its specs:rc 550cc enjectors,aem fuel rail,walbro fuel pump,aem 3.5 bar map sensor.hondata s300...i was runing good at 10.5 afr and the car was going really good,but then my wideband shows 14.0-14.7,fuel pressure is 3 bar,boost is 0.7 bar and going really bad.What can the problem be?
HAs the car been tuned on the dyno?
mike93hatch
Post by mike93hatch »
10.5:1 is pretty rich... have it tuned on a dyno by a professional tuner.
agentboost
Post by agentboost »
did you get the car tune? check the fuel psi under load, there might be a leak in the fuel system, are you geting boost spikes?
