I need help wiring the relay for vtec on non vtec ecu.
V-Spec race development
Post by V-Spec race development »
Hi I'm sorry if this been ask before or I'm not really understanding the diagram on how to wire the relay to activate vtec on a PO6 non vtec ecu. please help. thank you.
If you are unsure of how to wire it with the diagram, then you need to contact a shop that is familiar with wiring to help you with this. If you wire it incorrectly you may damage the ecu.
Spunkster, question for you, do I need to cut the wire from the ecu pin A15 to the relay or can I just spliced into it. thank you.
It must be cut. It cannot go to whatever it was originally controlling.
ok thanks a lot.
