Reverse doesn't lock out ('06)
eurorsx
Post by eurorsx »
I just installed K-Pro and when I shift, it doesnt lock out my reverse. What may be the cause of this?
drumnatural
Post by drumnatural »
Your ECU isn't from an 02-04 RSX Type-S
what is the code on the side of the ecu?
eurorsx
Post by eurorsx »
Spunkster wrote:what is the code on the side of the ecu?
Alright I found two lines:
37820-pnf-a12
230086-4301
I hope this isn't the wrong K-Pro that I purchased =/ The guy who had it before had it on his EK with a total K swap.
The PNF does not have the reverse lock. It is from a Civic Si. You'll just have to unplug the plug from the reverse lock solenoid. This was the ecu you provided. We recommend the use of a PRB for the 05-06 Type S and a PND for the 05-06 Base. The use of the adapter with an engine swap is not recommended or supported.
eurorsx
Post by eurorsx »
Ah, its the K-Pro that I bought from the guy. Well I am going to be careful with it, but last question is it bad for the tranny if I don't have the reverse lock out and plus do I need to unplug the switch from the tranny or can it be plugged in?
eurorsx
Post by eurorsx »
bump
As previously stated: "You'll just have to unplug the plug from the reverse lock solenoid."
Safety is dependant on the driver as you will be the one shifting the gears.
