Need a base map for b20vtec.
frakinstine
Post by frakinstine »
I have b20vtec with built bottom end and stock gsr head. Any fuel maps to start with would be nice. The motor is as listed.
bottom end bord to 85mm
wiseco 11.0- 12.0 compression range pistions
eagle connecting rods
gsr water pump
7 lbs flywheel
stock obd2 gsr head
stock gsr butter fly intake manifold
brospeed header
2-3/4" header back exhaust
skunk2 tunner cam gears
310 injectors
after market fuel pressure regulator
cold air intake
jdm typeR tranny and stage 5 clutch
a 255 walbro fuel pump don't remember what the shell came with
motor is about 12.4:1 compression
planetspeed
Post by planetspeed »
Hi Spunkster/Hondata! any basemap on the above mentioned engine?Thank you.
Go to File, New and start from one of the calibrations there.
peruvianB20vtec
Post by peruvianB20vtec »
i run my b20vtec with this map, my set up is similar but i'm using 440 cc injectors, good luck
Spunkster wrote:Go to File, New and start from one of the calibrations there.
hpmx18
Post by hpmx18 »
peruvianB20vtec wrote:i run my b20vtec with this map, my set up is similar but i'm using 440 cc injectors, good luck
my setup is almost the same exept for 13cr n strocked with 550cc
can you post that map again
