Whoa im new
Kingkoopa
Whoa im new
Post by Kingkoopa »
I was thinking about puttin a turbo on my civic...
It has a JDM SOHC ZC motor... i was gonna swap out the pistons ect and add a turbo dont i need to reflash the ecu or something to make my power be good?
Thx ill check this soon
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
