Is It a bug ?
JITU
Is It a bug ?
Post by JITU »
Hi,
I am running S300 ver 1.3.1.0 on my JDM P30 ECM, I have hooked up my PLX Wideband analog o/p to D10 ELd to measure wideband AFR (ELD Disabled), under Voltage/Lambda Conversion in parameters. I have set it up as Voltage=0.00 > 10.00 AFR & Voltage = 5.00 > 20.00 AFR. Now if i go to main menu under Options> Settings> Units > Lambda Unit & select Lambda instead of A/F Ratio this funny thing happens, under parameters the voltage/lambda conversion the 0.00V now reads as 1.47 lambda & 5.00V reads as 0.74 Lamda. Should it not be the other way round? A richer mixture should have lower lambda value. its bit confusing sometimes. can you guys have a look.
Or am i wrong somewhere? I would be very thankful if you guys let me know at the earliest.
jitu
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
Double click on AF in the sensors list and change it to read AF instead of Lambda.
