Weird Problem
awadkhan
Weird Problem
Post by awadkhan »
installed hondata in p08 and tried it on a prelude with h22a it worked fine thn i tried it in another car with h22 its a civic 98 swapped with h22.... there are no error codes car starts fine but when u give it throttle it starts dying as if there's a fuel cut or a huge amount of ignition retard above 2K rpm...?? wat could be the issue wiring problem or nething but there are no error codes showing in hondata when u put it in the civic with h22 swapped...
Impossible to tell without the calibration and a datalog showing the problem.
