New to Hondata
teamx
New to Hondata
Post by teamx »
Hi guys.
I'm planning a custom turbo setup on my '99 Balllade Vtec (Similar to the Civic Si in the States).
I want to use the Hondata S300 system to run it all.
As I'm in South Africa I'm a bit concerned about compatibilty issues.
Any help would be welcome.
Ps. My knowledge of ECU's and ECU tuning is very limited.
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
