Base map question.
WTMRACING
Base map question.
Post by WTMRACING »
I have a base map for 650's but i'm useing 550's,do i make my adjustments on overall fuel trim? if so do i adjust up or down.
You should make changes to the injector size first then make adjustments to the overall fuel trim based on your wideband readings and then do fine tuning in the tables.
