how do i run high an low boost?
high_octane
Post by high_octane »
can some one explain to me how this works? Do i need to wire somthing up? or is it hooked up already? Example the ac switch do i just set it up an then hit the ac for low an high booost?
You must wire it up to the desired input you have selected in Smanager. You may want to go to Help, Contents and search for Boost control and read about thte boost control parameters.
