Can't run s200
quik1
Can't run s200
Post by quik1 »
I recently purchased a hondata s200 with a base program, when i installed it into my vehicle the program seemed like it did not work. The car sputtered and would not rev past 3000 rpm. I went and got another chip burnt and the same thing happened. I put a p30 in while I waited to bring the hondata in to get fixed and tuned. The shop called me and told me the hondata would not work in my car they had tried 3 different boxes and 3 different computers. They finally tried to put the s100 in and that seemed to work. The only problem is that they can't tune it properly because they can't datalog. I would like to get the s200 going and was wondering if anyone else has had a similar problem or any suggestions. Sorry for the long post. Thanks in advance.
QUICKSILVER RACING
Post by QUICKSILVER RACING »
If it works with s100 then it should work with S200. Find another hondata dealer.
Your problem is outlined in the manual. Bad ROM, Bad connection between INT BoX and ECU or ECU gone BAD.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
quik1
Post by quik1 »
Ya but it doesn't work.I was there we tried different boxes, different rom, different computer. We then put the one that didn't work in my car into another car and it worked fine. I've triple checked all my sensors and vacume lines exc. nothing wrong. The s100 doesn't work that good either though, sometimes it gets really choppy when the accelerator is pushed just slightly.
Make sure jumper J12 has been cut in the ecu.
