CRVTEC Basemap for s300
aroon
Post by aroon »
hi guys
after a little bit of info
firstly what basemap would i use on my crvtec the spec is as below
Its got a stock b20z bottom end,
port polished head with CTR cams and valvetrain,
ITR intake manifold, ITR Injectors, ITR fuel rail, ITR throttle body, ITR LSD Gearbox,
ACT heavy duty full face clutch, Fidanza light weight flywheel,
polybush engine mount inserts, hondata intake manifold gasket, mugen 4-1 exhaust manifold, 5zigen exhaust, custom decat, high voltage engine stabiliser, methanol injection, apexi vafc 2,
ps what basemap would you recommend i use or has anyone got one i could use, currently using a b20 basemap with no vtec with crower cams that cam on the cd when i bought the s300 but have just added the vtec to it and incresed rev limit. Would you guys suggest i keep this one and play with it or start again with a itr map.
what revs limits would you guys recommend i stick to have to the car to as much as 8900 with no problems but am thinking this might be a little high for a stock b20z bottom end.
any help would be most appreciated
aroon.
This needs to be tuned on the dyno. Try contacting your tuner for a basemap to help you get it to the dyno safely.
