my car is acting strange.... please help!!!!
ctr99
Post by ctr99 »
ok i got my car running after so many trial and errors i was getting no spark but after i changed the ignition switch it started. ok now is the weird part i can run my car with no crank angle sensor i turned the key and let it cycle until it gets a engine check light then it starts and goes on limp mode and runs ok until i try to rev it and it response like shit,it pops, and struggles and when i go out to plug the sensor back in and clear the error code po335 as soon as i cleared it it back fires and die out and after that i cant start it again unless i unplug the crank angle sensor. so can any one help i am very frustrated from this project and would like to see this project run perfect!
94 civic cx
hybrid racing con. harness
wiseco pistons 11.7:1
eagle rods
k-pro
stock k20a2 camshafts
k20a2 block (stock engine out fitted with pistons and rods)
__________________
This sounds like a wiring problem. I would suggest contacting Hybrid to help you sort this out.
ctr99
Post by ctr99 »
ok today i took off my timing cover and checked the timing as i was inspecting it i notice the ckp pulse plate tooths was chipped off so i replaced it and guess what it runs perfect, purrs like a beast.
