Should I upgrade to K-pro from reflash?
salsamike
Post by salsamike »
I have a 03 RSX type S with the following mods: JRSC w-reflash, CAI, DC shorty header, high flow cat and Greddy evo 2 exhaust. I have noticed that when I disengage the clutch, the idle will drop down to about 500 rpm (feel like it is going to stall) then the computer will bump it back up to 900 rpm. If I upgrade to the k-pro, can this issue be fixed. I don't want to spend the extra cash and still have the same problem.
You will have the ability to adjust all parameters once you have upgraded to K-Pro.
salsamike
Post by salsamike »
Thanks for the quick reply! I am going to upgrade, but I was wondering if when you guys return the k-pro, will it have some sort of default setting, or does it need to be tuned immediately? Also, what parameter needs to be adjusted so the idle will not drop to the point of stall.
You will have to upload the base calibration you wish to use and then you can begin tuning from there.
