Full Throttle Shift & Launch Control keeping Cruise Cont
C_Rock77
Post by C_Rock77 »
I've been reading up, and see that the FTS and LC can use the clutch switch that's already in the car. My question is how do I use this feature with my S300 and KEEP my full Cruise Control functionality?
From what I understand, you can use the clutch switch for FTS and LC, but it has to be disconnected from it's original use.
How do I accomplish this?
C_Rock77
Post by C_Rock77 »
Nobody can help me with this?
Jumper the wires together that connected to the cruise control switch. Cruise will no longer shut off if you hit the clutch.
C_Rock77
Post by C_Rock77 »
Spunkster wrote:Jumper the wires together that connected to the cruise control switch. Cruise will no longer shut off if you hit the clutch.
There any way to do it and keep the original functionality of the switch?
Could you tell me in a little more detail what you mean saying to jumper the wires together?
No.
you take the 2 wires and join them together.
C_Rock77
Post by C_Rock77 »
Spunkster wrote: you take the 2 wires and join them together.
The 2 wires of the switch?
GTMcoupe
Post by GTMcoupe »
C_Rock77 wrote:There any way to do it and keep the original functionality of the switch?
Install a second switch and wire it to an alternative available pin out such as MIL connector, Simple
WEST
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
