map senser screwing up
rdelsol95
Post by rdelsol95 »
my map sensor is reading 4 psi at idle and hits around 24 psi of boost in the datalog but both my greddy boost contoller and my autometer boost gauge read 9 psi here are a couple datalogs and my calibrations i have the motec 3 bar map senser installed and i got it from my hondata dealer
street legal go kart
Under options, settings, units, make sur eyou have the units base set to atmospheric
rdelsol95
Post by rdelsol95 »
i already did that
You datalogs showed up normally over here. IT is your settings that are making you have strange readings. Double check them. Also make sureyou have the settings in the sensors list correct.
