GM 3 BAR
BOOSTEDFERIO
GM 3 BAR
Post by BOOSTEDFERIO »
hi - sorry if this is a dumb question. i just installed a gm 3 bar instead of my stock map. i went under the option to change the type of map sensor. i chose custom a scrolled through and did not see the gm 3 bar as an option. am i missing something. is it listed as some other type of map? i would appreciate the help. thanks!
IT may be similar to the Motec, but then again it may not be. THere are several different GM sensors so we do not recommend their use.
Tchleung
Post by Tchleung »
what part# is your GM map?
Panta83
Post by Panta83 »
I got the same prob
Here's the map
Panta83
Post by Panta83 »
UP ?
Please ?
laziebun
Post by laziebun »
You have to go unde the custom and figure out the Scalar and offset yourself..... so.... check this out i think this what you might be looking for http://hondata.net/forum/viewtopic.php? ... ght=#23621
let me know if this helps GL
ExViTermini
Post by ExViTermini »
I've noticed a lot of people that are using the GM/MSD 3 bar map have the Motec 3 bar selected. There is an option in the newest release though that does have the GM 3 bar as a selection.
I personally am using the Motec 3 bar setting and it appears to work just fine...
Panta83
Post by Panta83 »
Same thing !
I run the Motec 3 bar right now and it works fine :wink:
