gain feature for boost by gear
weltall
Post by weltall »
are there any plans for this to be added in a future release
just so us full race guys can run spring pressure
avcr users and profec users can run spring pressure fine with out creep or boost loss across the rpm range
The next version of KManager has boost by gear & rpm, and you'll be able to get around the problem. It's due for release in the next two weeks.
However, be aware that the real solution is to fix the problem - which is that the manifold is giving boost creep.
