Aem wideband with hondata s300
Teamdiesel
Post by Teamdiesel »
I have installed an AEM wideband but am having problems integrating it with the Hondata. The help files are of not much help so I need you help. I have hooked up the AEM wideband to the ELD D10 and clipped one end of the R136 & R138 resistors and cut the ELD wire and hooked the white 0-5v wire to it. Now I am having a hard time in getting my hondata AF meter in the display function to read the A/F ratio as the wideband. When the wideband is saying 13.1 the AF meter is saying 0.93. Could someone walk me through the sequence from where I am stuck?
2000' JDM CTR, 12.704 @106.38mph w/1.7 60ft
Go to Options, Settins and change the units tabe to read AF instead of Lambda.
panapower
Post by panapower »
is there a schematic for this integration with the AEM wideband sensor? thanks.
It will be similar to this: http://www.hondata.com/techplxwiring.html
The AEM does not have dual outputs, this is why we only recommend the PLX widebands.
