need help....kpro issues
vivalive
Post by vivalive »
my Iat engine is on after installed kpro, and it lock my cams at 0 degree..
i need help fixing this issues.. could someone help me.. i've checked all the wiring and refered to the services manual..
k20a3 2005 model rsx.
Have you tried the ecu in another vehicle?
vivalive
Post by vivalive »
no i havn't... my kpro is brand new shouldn't there be no problem?
by the way. its a type-s ecu k-kpro.
vivalive
Post by vivalive »
Spunkster wrote:Have you tried the ecu in another vehicle?
does the type-s and base rsx share the same sensor on the throttle body?
i know the throttle body is different but not sure about the sensor?
The sensors are all the same. Please try the ecu on another vehicle. This will tell you if it is a problem with your ecu or with your car.
vivalive
Post by vivalive »
Spunkster wrote:The sensors are all the same. Please try the ecu on another vehicle. This will tell you if it is a problem with your ecu or with your car.
will i have check engine if i ran my stock 2005 ecu with 2004 o2 sensor?
You have asked this before. You must use the 02-04 o2 sensor with the K-Pro. You are trignto determine if there is a problem with the IAT, so don't worry about other errors when testing. Just look for the IAT error.
vivalive
Post by vivalive »
Spunkster wrote:You have asked this before. You must use the 02-04 o2 sensor with the K-Pro. You are trignto determine if there is a problem with the IAT, so don't worry about other errors when testing. Just look for the IAT error.
i've change the 1st o2 sensor, do i need to change the o2 after the cat?
no
vivalive
Post by vivalive »
when i unplug my IAT kpro is still throwing " IAT LOW VOLTAGE" and the temperature reading is the same 95f.
what should i do? my turbo kit is comming in next week... i want to get this fixed. i don't want to use Emange!
type-s ecu/ 05 base rsx.
vivalive
Post by vivalive »
could i only buy a new harness?
There is no need to buy a harness since you have not completed all the troubleshooting steps yet. You need to try this ecu in another vehicle to see if it is getting the same IAT error there.
vivalive
Post by vivalive »
Spunkster wrote:There is no need to buy a harness since you have not completed all the troubleshooting steps yet. You need to try this ecu in another vehicle to see if it is getting the same IAT error there.
there isn't another 05-06 rsx i could try on.... could i try it on an 02-04?
Yes you can try it on any RSX, just don't use the adapter if it's an 02-04.
vivalive
Post by vivalive »
Spunkster wrote:Yes you can try it on any RSX, just don't use the adapter if it's an 02-04.
today i took out my Iat, and figure out its cooked/melted. could there be a short somewhere?
