Big problem - wont read MAP sensor!!
OTT
Post by OTT »
setup:
OEM sensor on throttle-body.
GM 3bar on firewall
wire harness is stock but with 3bar sensor spliced into OEM wiring.
Checked voltage coming out of 3bar using a piece of tube to blow into, voltage changed fine, checked voltage at ecu connector, voltage comes through just fine.
The problem is hondata just reads -29psi
plugged the OEM sensor in, same reading, re-uploaded a new maw with just injector sizes, then on the sensor info pane MAP just says 0psi! on either sensor. I had selected the correct types for each sensor.
Im guessing this is a ECU issue? but the ecu was socketed by Hondata! throgh Jeff @ importbuilders.
any advice tips???
can I sent it back for testing? or any better advice?
The first step would be to try the ecu in another vehicle and see what happens. This will rule out any wiring problems with your car.
OTT
Post by OTT »
no wiring issues, checked voltage at sensor and at ecu connector after adaptor harness. Tuned fine on AEM.! :?
