Secondary map never activates.
Too_smooth
Post by Too_smooth »
In the past when I activated the switch I would see the map switch in SManager. Seems to me that this stopped working for me when I upgraded to 1.3.3. The system sees the switch when I switch it on and off. I also have changed the switch to use one of the other switches that I use for data logging and launch control. Those work fine regardless of which switch I set to activate them.
I'll upload the map just in case.
Change the minimum engine speed to 200rpm
change your engine load to something sensible like 70KPA and 500KPA
and then set your throttle to somethign above 0 as well
The settings you have can never be met
Too_smooth
I'll try that...it's funny that it worked before though. I'll let you know if that works.
Too_smooth
Thanks...it works again.
I changed the mininum engine speed to 100 and engine load to -14.5. I left throttle at zero.
Basically I want the lowest values in there possible so the map would switch as soon as I hit the switch.
