S2000 Kpro Fitment
JustinC
S2000 Kpro Fitment
Post by JustinC »
Was wondering how the fitment was on the S2K. I can't seem to get both holes to line up. I can get it in the mount..place the rubber thing in and then can only bolt in the hole closes to the door...the other one is about a half inch off.
Any tips...also do you leave the USB cable installed ?
It should fit perfectly. The USB cable should be left in since it will be nearly impossble to plug it in after the fact.
From the Hondata website:
JustinC
Post by JustinC »
Spunkster wrote:It should fit perfectly. The USB cable should be left in since it will be nearly impossble to plug it in after the fact.
Okay, well I will take the bracket off the ecu and then test fit it, b/c it doesn't fit perfectly for me. Maybe there is something in the way...I can't see.
JustinC
Post by JustinC »
I finally got it to bolt up, but it took me an hour of shoving it against the rubber mount to get it to sit properly, I think maybe that bracket is a little tight against the rubber piece.
JustinC
Post by JustinC »
