S2000 KPRO Maps
JustinC
S2000 KPRO Maps
Post by JustinC »
Was wondering why Hondata doesn't include the map for the 06+ reflash in the bundle of maps in K-Manager, all the 04+ guys could technically use that map instead of just the base map for the ap1s that is included.
Because it is not compatible with K-Pro. It uses a different type of ecu.
JustinC
Post by JustinC »
Spunkster wrote:Because it is not compatible with K-Pro. It uses a different type of ecu.
Fair enough, just figured it could be moved over since it would be roughly the same timing/vtec settings/fuel values.
dmramos
Post by dmramos »
will you guys provide a map for the ap2 by any chance?
Hopefully in the near future
dmramos
Post by dmramos »
any news on a stock ap2 map? i will be installing kpro this weekend so i need a base map. thanks
We have not had the opportunity to dyno tune a F22 at this time. You will have to start with the AP1 calibration and increase the overall fuel trim for the increased displacement and begin your tuning from there.
