Boost solenoid not working
verlee24
Post by verlee24 »
1994 honda civic EX
s300 w/ boost and GM solenoid
custom turbo kit
wastegate spring is 7 psi, set the boost to 7 psi, but it doesn't hold it and boosts till the cut at 10 psi,
how do i get it to hold 7 psi?
Td16z6
Have you used the fixed duty cycle to create a table so you know what duty cycles create what level of boost?
The Pressure vs Duty Cycle table contains a lookup of pressure valves which correspond to a solenoid duty cycle. The values for this table must be set by using a fixed duty cycle (see Control Method) and noting the resulting manifold pressure. Note that different ambient conditions will result in slightly different boost pressures for the same duty cycle.
