3 bar map sensor incorrect voltage
Joelspy70
Post by Joelspy70 »
In troubleshooting an issue with my MSD 3 bar map sensor I noticed the Map signal wire constantly reads around 5 volts when plugged in with key on engine off. When I plug the stock map sensor in it reads around 2-3volts. Does this mean I am using the wrong scalar?
Joel
03 RSX-S
Peakboost Turbo Kit, Full 3" Turbo back Exhaust, RC 750cc Injectors, NGK-BKR8EIX, Full Race Vaccum Block, Odyssey PC680MJ Battery, Innovative Mounts, Valve cover engine ground.
Kpro Version: 1.2.8
Does it read correctly when the car is running?
Joelspy70
Post by Joelspy70 »
Spunkster wrote:Does it read correctly when the car is running?
Oddly enough the values in hondata barely change. The most I have seen it move was .5 psi to .6
Joel
03 RSX-S
Kpro Version: 1.2.8
