Crash at startup with 1.2.3.3
PsyKotyk
Post by PsyKotyk »
When posting a KPro problem with your vehicle, please include:
- Serial No: 4900
- Make/Model: 2003 Acura RSX-s
- Product: K-Pro
With the latest version of K-Manager 1.2.3.3, I get a crash on startup (before the screen is even created).
I'm running Windows 2000 Pro, 1G ram, P4-1.8Ghz, Dell Inspiron 8200. Previous version of KManager worked fine.
KManager.exe C:\Program Files\KManager\KManager.exe N/A N/A Binary was not built with debug information. 1 1.02.3.3 2/25/2008 1:09 PM 00400000-00874B6E [1996] KManager.exe: Native
There is a null ptr exception at offset 0x00872CF0.
ESI 00000000
EAX 7C596A05
EDI 7C596A0A
00872CD9 FF 95 00 04 00 00 call dword ptr [ebp+400h]
00872CDF C7 85 DA 4D 00 00 01 00 04 02 mov dword ptr [ebp+4DDAh],2040001h
00872CE9 8B C7 mov eax,edi
00872CEB 2B C6 sub eax,esi
00872CED 83 E8 05 sub eax,5
00872CF0 C6 06 E9 mov byte ptr [esi],0E9h
00872CF3 89 46 01 mov dword ptr [esi+1],eax
Is there any logging I can turn on to provide more info?
PsyKotyk
Post by PsyKotyk »
I back down to version 1.3.2.2 and I'm seeing the same crash. It may be related to my laptop being put into standby. Will try a fresh reboot when I'm home.
DOes your computer have internet access when this is happening?
PsyKotyk
Post by PsyKotyk »
I do have internet connection when I launch. I backed down to 1.2.3.1 and it works again. Then I upgraded to the latest and no dice.
Has the target platform/architecture been changed in recent version? I'm able to do a dumpbin on the version that works and it shows all the symbols and imports. On the latest, I get the result below, which shows it's not even recognized at a complete executable (unless you guys are being crafty and doing a 2 stage load and encrypting/compressing the main executable). When I run it under strace, I don't even hit a single system call before it exits from a first chance exception.
My gut says it has to do with me running Win 2K pro still.
Microsoft (R) COFF/PE Dumper Version 8.00.50727.762
Copyright (C) Microsoft Corporation. All rights reserved.
Dump of file KManager.exe
File Type: EXECUTABLE IMAGE
DUMPBIN : warning LNK4078: multiple '.text' sections found with different attributes (E0000020)
Section contains the following imports:
kernel32.dll
86F1EE Import Address Table
0 Import Name Table
0 time date stamp
0 Index of first forwarder reference
0 LoadLibraryA
0 GetProcAddress
0 VirtualAlloc
0 VirtualProtect
0 VirtualFree
0 GetModuleHandleA
Summary
193000 .text
2E1000 .text
KManager only works with Windows XP and Vista 32 bit
PsyKotyk
Post by PsyKotyk »
It seems these last two updates are for preventing reverse engineering of your product, at the sacrifice of wider platform compatibility.
The new releases don't take too kindly to attaching with a debugger or memory searching tools. I guess I'll be sticking with KManager 1.2.3.1 until such a time that an API is provided for accessing the sensors from my own apps.
Even just a simple TCP/IP socket that could barf out the sensor values would be ideal, without the risk of exposing any trade secrets. Just an idea.
Still a huge fan of what you have accomplished with the K-Pro.
