p75 obd1
elmkanudo
p75 obd1
Post by elmkanudo »
well guys I,m new to this and my english to so please help I have a 1994 integra ls we did a swap with a b18ci 2000 obd2 can I chip the p75 obd1 to get the vtec and rpm tack work or I be better of woth a p72 obd1 please help
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
