ecu for B16B
cockknocker
ecu for B16B
Post by cockknocker »
would you suggest any spaciffic ecu from the handata ecu list, I have ODBIIa connection and a ex coupe? or does it really not matter once you have hondata installed? just tryin to figure what would be best before I spend my hard earned cash
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
