3 bar map sensor for s300
boosted crx-r
Post by boosted crx-r »
what is the correct 3 bar for the s300 and where can i purchase it from??
shut up and boost it!
Rather than use a 3 bar, you will be better off using the new ondata 4 bar map sensor that just plugs directly in without any rewiring needed.
http://www.hondata.com/4barmap.html
JDC2TypeR
Post by JDC2TypeR »
i'm using the hondata 4 bar map sensor but i cannot find the hondata 4 bar map sensor setting in the s300 manager. i already look under parameter then map and then i look at the list of map sensors and theres none. the only 4 bar map sensor on there is the omni 4 bar and the rest are 2, 2.5, 3, and 5 bar map sensor from motorola, motec, aem, msd, neetronic, rdx, and custom. how can we choose the hondata 4 bar map sensor if it's not in the list? i have the most up to date s300 manager program and i already look in the older s300 manager program and there is nothing there. hondata needs to put their 4 bar map sensor into the parameter map list because we are buying their $130 dollar hondata map sensor and it's not in the map list.
Omnipower and Hondata are the same sensor.
