Injector upgrade fuel comp ??
Daonboost
Post by Daonboost »
i upgraded my Injectors from rc 750cc to precistion 1000CCs under the fuel trim tab will i have to change the Voltage compensation under the fuel trim window?? i no ovesly il have to change the injector size from 750 to 1000 now the voltage comp reads
Volts...0.0 8.1 10.1 12.1 14.2 16.1 24.6
deadtime...1.49-1.49 0.96 0.68 0.49 0.35 0.35
If i have to change that how do i get the readings to do that ?? :?:
Usually from the manufacturer of the injector, or someone who has tested the injectors.
