boost controller and data logging
SPOOLIN
Post by SPOOLIN »
when not using the low/high boost control settings, which tab does the s300 use for boost control? Low or High?
my data logging only seems to be catching 4th gear, whats going on, i havnt changed anything to do with ingition, i did upgrade versions, it was logging full runs the last time i was at the track. Really the only thing is a retune and online upgrade.
www.MSSRACING.com
9.29 | 6.20 | 167
It uses the low table.
I don't understand what you are asking.
SPOOLIN
Post by SPOOLIN »
im asking what i stated. Even when you disable the switch option for switching between low and high, you can still program both tables, so for the sake of making sure my boost is the right boost, ive been changing both tables and its really annoying so i need to know it the software is only using the high or if its only using the low table when the switch option is disabled.
low?
as far as datalogging. I went to the track a few months back and datalogged fine. now i go back the other day and its only catching maybe 4th gear by the way the sensors are looking and mph and such. Only thing we changed was a retune and i know i auto updated my software.
www.MSSRACING.com
9.29 | 6.20 | 167
locash
Post by locash »
The software only uses the low boost setting by default.
There is a bug in the gearing tab with Smanager, and it will zero out all values when you pick a transmission. Manually type them in and it will be fine until they fix it.
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
