Cant Uploading nor Downloading with SManager 1.3.4
NA_junkie
Post by NA_junkie »
I Downloaded the New 1.3.4 of Smanager. I had 1.3.1 and was able to upload and download from My ECU.
When i Download i am getting and error telling me " Floating point division but zero" and when i upload i am getting a fatal error and it keeps poping up. The Red light in my ECU stays on when this happens and the CEL doesnt go away.
I had to unistall Smanager and go with a lower version 1.3.1 and i was able to download and upload in order to get the car driving.
I read a few post and the guy were sayingclose the program and reopen and try again... that didnt work
I also read to load a basemap from the presets and when uploading, it will ask to update the firmware. I did that and i still have the problem.
any suggestions?
JITU
Post by JITU »
Try installing smanager 1.3.4 on a different folder & redo again.
Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap.
YOu shouldn't be downloading the file from the ecu. You should already have the file saved on your laptop. Open that calibration using the newversion and then uplaod it to the ecu. It will need to update the firmware then should upload the cal. You may also want to just upload a stock calibration from File, New the first time if your calibration is having difficultiy uploading as it may be corrupt from downloading it from the ecu.
samuel_pr100
cannot download the calibration of the ecu
Post by samuel_pr100 »
Hello NA_junkie, please, you might send for e-mail (samuel_pr100@yahoo.es) the smanager version 1.3.1 or say to me where I can download it. I have the same problem that your and I cannot download the calibration of the ecu.
Thank you very much in advance.
